Disables RIP from redistributing routes from other routing protocols.
| bgp | Specifies BGP routes. |
| direct | Specifies interface routes (only interfaces that have IP forwarding enabled are exported). |
| e-bgp | Specifies external BGP routes. |
| i-bgp | Specifies internal BGP routes. |
| ospf | Specifies all OSPF routes. |
| ospf-extern1 | Specifies OSPF external route type 1. |
| ospf-extern2 | Specifies OSPF external route type 2. |
| ospf-inter | Specifies OSPF-inter area routes. |
| ospf-intra | Specifies OSPF-intra area routes. |
| static | Specifies static routes. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies ISIS Level 1 routes. |
| isis-level-1-external | Specifies ISIS Level 1 External routes. |
| isis-level-2 | Specifies ISIS Level 2 routes. |
| isis-level-2-external | Specifies ISIS Level 2 External routes. |
Disabled.
This command disables the exporting of BGP, static, direct, and OSPF-learned routes into the RIP domain.
The following command disables RIP from redistributing any routes learned from OSPF:
# disable rip export ospf
This command is available on all platforms with a Base license or higher as described in the Switch Engine v33.1.1 Licensing Guide document.
